AUTOADOPTSIZES system variable
Auto adopt sizes
When On, the wall width and height, and the slab thickness is copied from the highlighted existing geometry, when using BIMQUICKDRAW.
Tylko BricsCAD
| Wpisz: |
Boolowskie |
| Zapisano w: |
Rysunek |
| Domyślna wartość: |
Na |
| Możliwe wartości: |
Off (0): The wall width and height, and the slab thickness is not copied. On (1): The wall width and height, and the slab thickness is copied. |
