DEFAULTSTYLEPIPEELBOW90 system variable
Default style for pipe elbow (90 deg)
Controls the default style in use while BIM FlowBends with 90 degrees angle converts to an Std part.
BricsCAD only
Type:
String
Saved in:
Registry
Default value: ASME B16.9 Elbow LR 90 Deg
