LOGFILEMODE system variable
Log file mode
Specifies whether a logfile is maintained or not. A logfile contains each executed command. These logfiles are saved in the folder specified by the LOGFILEPATH system variable.
Type: | Boolean |
Saved in: | Registry |
Default value: | Off |
Possible values: |
Off (0): Don’t maintain log file On (1): Maintain log file |
