NOMUTT system variable
No muttering
Suppresses text in the Command line.
When on, the Command line will stop prompting all the options and actions.
Type: |
Boolean |
Saved in: |
Not saved |
Default value: |
Off |
Possible values: |
Off (0): Don’t suppress Command line prompts On (1): Suppress Command line prompts |
