SPLMETHOD system variable
Spline Method
Indicates the default method for spline creation (fit points/control vertices).
Defaults to 0 (fit points) on application start.
| Wpisz: |
Krótki |
| Zapisano w: |
Nie zapisano |
| Domyślna wartość: |
0 |
| Możliwe opcje: |
0: Create splines using fit points 1: Create splines using control vertices |
