BIMTAG command
Creates associative tags.
Icon:
Creates associative tags in generated BIM section drawings for the corresponding building entities in a 3D BIM model.
Note: This command can only be used on section
viewports.
Note: The GENERATEASSOCVIEWS system variable must be ON when
generating or updating BIM tags.
Method
The tags are created automatically for all building elements in the selected viewport.
Note: Tags are created as multileader entities using
multileader styles in _SectionTag.dwg. The content of such a multileader style
can be a field referring to a property of BIM entity type or a block with
attributes. Each attribute refers to a property of a BIM entity type. BIM entity
types are linked to a multileader style in _TagTypeToStyle.xml. All source files
can be found in the Support folder, for example:
C:\Users\<UserName>\AppData\Roaming\Bricsys\BricsCAD\V22x64\en_US\Support\Bim\Sections.
Note: Section indicators, story indicators and grid
callouts are generated automatically within section update.
Options within the command
- Auto
- Creates tags automatically for all sectioned building entities in the selected viewport, including section indicators, story indicators and grid callouts.
- Manual
- Creates tags for selected entities in sections and elevations.
- Box selection
- Creates tags for all entities selected in sections and elevations.
Note: Both Manual and Box Selection allow you to tag
background entities.
- Current mleader style
- Allows to use the current multileader style instead of the default style for selected sectioned BIM elements.
- change Tag type
- Changes the type of the selected tags.
- cOmposition
- Tag with all materials of composition of the sectioned BIM element.
- Load-bearing directions
- Inserts a loadbearing direction symbol when a generated line of a slab solid is selected. Make sure the load bearing direction is set by the BIMSETLOADBEARINGDIRECTION command.
- Spot-elevation
- Inserts a tag that indicates the elevation of the identified point in elevations and vertical sections.
- Update existing
- Updates the existing tags in the selected viewport. The position of relocated tag blocks is preserved.
- update existing and add New
- Updates the existing tags in the selected viewport and adds new tags.
- Regenerate all
- Updates all tags in the selected viewport. Repositioned tag blocks are moved to their default location.
