BMSEQUENCE command
Allows disassembling by clicking away components or groups of components.
BricsCAD Mechanical
Method
Select one or more entities for the next step and press Enter. Do this till the end step. After the entire assembly sequence is specified, enter a unique name for the assembly sequence.
Note: Press CTRL+Z to local undo to previous assembly step.
Note: Only mechanical instances can be selected.
The assembly sequence is registered as an exploded view block under Representations in the Mechanical Browser panel. Step number is descending so that the numbering is ascending in the BMASSEMBLYINSPECT command. The sequence to the exploded view block is reversed to represent assembly sequence or disassembly sequence.
Note: The sequence can be inspected with BMASSEMBLYINSPECT command.
Options within the command
Finish
Finishes the creation of the sequence.
