DMSIMPLIFYALL command
Simplifies the geometry in solids, within drawings inserted as external references.
BricsCAD Shape; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM
Removes unnecessary edges and vertices, merges seam edges, and replaces the geometry of faces and edges by analytic surfaces and curves, if possible within the user-specified tolerance.
Note: It is recommended to always run this command on imported drawings with inserted external references.
Options within the command
Entire model
Simplifies the entire model.
SEttings
Allows you to access the command settings.
Geometry
Define the geometrical settings.
ON
Switches topological/geometrical simplification on.
OFF
Switches topological/geometrical simplification off.
Topology
Defines the Topology settings.
Auto
Simplifies the detected geometry or topology.
