DXFOUT command
Opens the Select DXF file dialog box.
Alias: DX
Opens the Select DXF file dialog box to save data from the current drawing to a DXF file.
Options within the command
Enter decimal places of accuracy (0-16)
Specifies the accuracy of real numbers in the DXF file. Some CNC (computerized numerical control) machines require 4 decimal places in DXF files.
Entities
Specifies the entities to export. If unspecified, all entities are exported.
Binary
Specifies binary format for the DXF file. If unspecified, the DXF file is exported to ASCII (text) format.
Version
Specifies the DXF version number. If unspecified, the DXF file is exported to the most current version. Exporting to an older version can cause some entities or properties to be lost.
