-LAYOUTMERGE command (Express Tools)
Merges entities from specified layouts into a destination layout via Command line.
Options within the command
Select Layouts to merge
Allows you to specify the layout names to merge. You can type multiple layout names, separated by comma.
Select Destination Layout
Allows you to specify the name of the destination layout.
Note: If the specified destination layout does not exist, the Command line prompt asks you if you want to create it.
Remove empty layouts?
Allows you to choose to delete empty layouts or not.
