-VISUALSTYLES command
Manages visual styles.
The command sets and manages visual styles at the Command line.
Options within the command
set Current
Sets a visual style for the current viewport. The options are:
  • 2dwireframe
  • Wireframe
  • Hidden
  • Realistic
  • Conceptual
  • Shaded
  • shaded with Edges
  • shades of Grey
  • SKetchy
  • X-ray
  • Other
  • cUrrent
Note:
  • Other option allows you to select a custom visual style. For example, BIM templates have specific predefined visual styles, Bim, Maquette, Render and See-through.
  • cUrrent option sets the current visual style.
Save as
Saves the current visual style by a new name when you make changes to the properties of a visual style.
Note: 2dWireframe visual style cannot be saved.
Rename
Allows you to rename custom visual styles.
Note: Default visual styles cannot be renamed.
Delete
Deletes a visual style by name.
Note: The currently-used style and those defined by the program cannot be deleted.
Lists the names of visual styles available in the drawing:
  • 2dWireframe
  • Conceptual
  • Hidden
  • Realistic
  • Shaded
  • Shaded with edges
  • Shades of Gray
  • Sketchy
  • Wireframe
  • X-Ray
