VSCURRENT command
Sets the visual style for the current viewport.
Sets the visual style for the current viewport in the Command line.
Options within the command
2dwireframe
Uses lines and curves to represent the entities' borders.
Wireframe
Hidden
Uses lines and curves to represent entities' borders, but hiding the faces that are not visible.
Realistic
Smooths the boundaries between the faces of the polygons and shades the entities. Materials attached to the entities are shown.
Conceptual
Although the effect is less realistic, it can help you notice the entities' details more clearly.
Shaded
The entities are smoothly shaded.
shaded with Edges
The entities are smoothly shaded, but they also have the edges highlighted.
shades of Grey
The entities are smoothly shaded with monochromatic, grey tones.
SKetchy
Uses only black and white, making the models look hand-drawn.
X-ray
Changes the opacity of the models, making them seem transparent.
Other
Selects a user-defined visual style that was created with the VISUALSTYLES command.
cUrrent
Specifies the current visual style and gives the opportunity to keep it.
Note: The styles named in this list are the ones included with the program.
