XATTACH command
Attaches an external referenced file in the current drawing.
Icon:
Alias: XA
Opens the Select reference file dialog box to select a DWG file to reference to in the current drawing. After selecting the file and choosing Open, the Attach external reference dialog box displays. It enables you to specify where and how to attach the DWG file. The attached file will be visible in the Attachments panel.
