XDATA command (Express Tools)
Attaches extended entity data (xdata) to a selected entity.
Icon:
Method
  1. Select an entity.
  2. Enter an application name. This will be the application ID.
Note: Use the XDLIST command to view the xdata attached to entities.
Options within the command
3Real
Allows you to specify 3 real numbers (group code 1010).
DIR
Allows you to specify a 3D World direction (group code 1013).
DISP
Allows you to specify a 3D World displacement (group code 1012).
DIST
Allows you to enter a distance (group code 1041).
Hand
Allows you to specify an entity handle (group code 1005).
Int
Allows you to specify a 16-bit integer (group code 1070).
LAyer
Allows you to specify a layer name (group code 1003).
LOng
Allows you to specify a 32-bit integer (group code 1071).
Pos
Allows you to specify a 3D World space position (group code 1011).
Real
Allows you to specify a real number (group code 1040).
SCale
Allows you to specify a scale factor (group code 1042).
STr
Allows you to specify an ASCII string (group code 1000).
Exit
Ends the XDATA command.
