CLIPROMPTLINES system variable
Prompt Lines
Controls the maximum number of floating lines of text momentarily displayed above the Command line. Applies only if the Command line is hidden, or floating with the CMDLINEUSEMINIFRAME system variable set to on (1).
Values between 0 and 64 are accepted.
Type:
Short
Saved in:
Registry
Range:
0 to 64
Default value:
4
