DMPERPENDICULAR3D command
Applies a perpendicular constraint between two subentities of two 3D entities.
Icon:
描述(D)
Applies a perpendicular constraint between faces or edges of a solid, or of different solids or surfaces.
Select the two subentities of the 3D entities between which the perpendicular constraint will be applied. Press the TAB key to select obscured geometry.
选项(O)
- 世界
- Allows you to select the WCS subentity as an argument.
- 图块
- Allows you to choose, as an argument, the subentity of the coordinate system of the block.
