LCONNECT command
Creates or modifies an L-connection between solids.
Icon:
描述(D)
Creates or modifies an L-connection between solids. Optionally disconnects L-connected solids.
之前 | 之后 |
选项(O)
- Select entities to connect
- Manually select the two entities you want to connect.
- 切换
- Allows to choose between two butted L-connections:or
or a mitered L-connection:
or a touching (disconnected) connection:
