View Detail dialog box
The View Detail dialog box displays the view details.
View detail for advanced (propagatable) details:
  1. Info
  2. Tolerance Parameters
  3. General Tags
  4. Solid Reference Tags
  5. Save
  6. Open
  7. Propagate
  8. Cancel
Info
Displays general information about the detail.
Name
Displays the name of the detail.
Category
Displays the category name of the detail.
Propagatable
Specifies if the detail is propagatable.
Path
Displays the path of the detail file.
Displays the parameters of the detail, or the option to parametrize the detail.
Parametrize
Opens the DWG detail file and executes the BIMPARAMETRIZEDETAIL command.
Note: If the details is already parametrized, this option is turned off, and the parameters are displayed.
General Tags
Displays the tags that generally identify the detail.
  • Click the cross button to delete tags.
  • Click the plus button to add a tag. The new added tags will be in an orange box.
Displays the tags that identify an individual solid reference from the detail. You cannot add reference solid tags here, you can only delete the existing tags.
Note: Tags are used to search for a specific detail in the library.
Note: Tags are automatically generated for the detail during the BIMCREATEDETAIL command.
Save
Saves the changes and closes the View Detail dialog box.
Open
Opens the DWG file of the detail.
Propagate
Propagates the detail. See the BIMPROPAGATE command.
Cancel
Closes the View Detail dialog box without saving.
View detail for basic details:
9. Add references
Add references
Launches the BIMADDDETAILREFS command.
