-BMBOMEXPORT command
Exports the content of a BOM table as a table with link, or to a .csv or .xlsx file.
BricsCAD Mechanical
Options within the command
Options for source BOM table
Bom table
Defines the BOM table that will be exported.
List tables
Lists the available BOM tables in the current document.
Current bom
Selects the current BOM.
template File
Defines the BOM table template that will be exported. The file path name has to be specified in the Command line.
Options for target
Table with link
Exports the content of the BOM table to another table with datalink, which allows to use the bill of materials like BIM schedules. Opens the Select file to save the BOM table template dialog box.
csv or excel File
Exports a BOM table to a .csv or .xlsx file. The file path name has to be specified in the Command line.
