-BMPARAMETERS command
Allows to list and edit the parameters of inserted components and associative arrays.
![BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-pro-mechanical-bim.png)
Allows to list and edit the parameters of inserted components and associative arrays. By pressing Enter, the parameter expression can be changed.
Note: Parameters of components nested inside an array can be changed or assigned to an expression.
Options within the command
- Edit
- Edits the value of a parameter.
- Delete
- Allows to reset a previously edited parameter to its default value.
- Link to parameter
- Assigns parameters as an expression for a parameter of a dimensional constraint (both 2D and 3D) associated with an entity which has been put into an associative array.
- Lists the parameters of the selected components in the Prompt History window.
