-IMPORT command
Imports geometry from external files at the command prompts.
Note: This command opens all file formats supported by the
IMPORT command.
Method
Specify the full path and file name of an importable file.
Note: Type ~ (tilde) to display the Import file dialog box,
which allows you to select a file to import.
Note: File types available for importing are the same as for
the IMPORT command.
