-PLOT command
Plots drawings to printers and to files.
Plots drawings to printers and to files, through the Command line.
Note: This command is meant for scripts and routines.
Method
Choose whether to proceed a detailed plot configuration.
Options
- Detailed plot configuration?
- Choose whether to change the plot configuration.
- Yes
- Prompts 16 options to configure the plot.
- No
- Prompts 6 options.
- Enter a layout name or ?
- Specifies the name of the layout to plot. Enter ? to list the layouts in the current drawing.
- Enter an output device name or ?
- Specifies the name of the output device (plotter or file). Enter ? to list the available plot devices.
- Enter paper size or ?
- Specifies the name of the paper size. Enter ? to list the available media sizes.
- Enter paper units
- Specifies the paper units: inches or millimeters.
- Enter drawing orientation
- Specifies the drawing orientation: portrait or landscape.
- Plot upside down?
- Plots the drawing upside down.
- Enter plot area
- Specifies which area of the drawing to plot.
- Display
- Plots the area shown in the current viewport.
- Extents
- Plots the extents of the drawing, ensuring all non-frozen entities are plotted.
- Limits
- Plots the limits of the drawing, as defined by the Limits command.
- View
- Plots the current view, or a named view. See View command.
- Window
- Plots a rectangular area defined by the user.
- Enter plot scale
- Specifies the plot scale factor.
- Enter plot offset
- Specifies the offset distance for the print.
- Plot with plot styles?
- Toggles the use of plot styles.
- Enter plot style table name
- Specifies the plot style table to use, which assigns properties to "pens," colors, and entities.
- Plot with lineweights?
- Toggles the use of lineweights.
- Yes
- Mimics lineweights assigned to the drawing in the print.
- Enter shade plot
- Specifies the shade plot. Overrides the visual style of the current view when printing model space.
- Write plot to a file?
- Determines whether the plot is sent to a file. If Yes, displays the Create plot file dialog box.
- Save changes to layout?
- Toggles saving the plot parameters to the model or layout tab.
- Proceed with plot?
- Toggles plotting of the drawing.
- Enter a page setup name
- Specifies the name of a page setup.
