BIMSECTIONOPEN command
Opens the drawing file related to a BIM section entity.
Icon:
Opens the drawing file related to a BIM section entity, or the 3D BIM model related to a BIM section drawing.
Method
There are two methods to use BIMSECTIONOPEN command:
- Select a BIM section entity in Model Space.
- Select a BIM section result (a viewport) in Paper Space.
