BMWELDING command
Creates a fillet or groove welding for faces (or two sets of faces) of different 3D solids.
Icon:
Method
Select the faces of the two 3D solids (members) between which the weld will be created, if
possible:
- For fillet welding you can select a face of the first member and one or multiple faces of the second member.
- For groove welding you can select one or multiple faces of the first member and one or multiple faces of the second member.
Note: When the operation is not possible for all selected faces, a notifying balloon will appear on the screen. Click More details... to open the Report panel where the faces not included in the operation are listed.
Options within the command
- Fillet
- Creates a fillet welding using one of the following sizes, according with the value of the
FILLETWELDINGCOMBINEADJACENT system variable:
- Input Z
- Specifies a value for the Z (Leg) length of the fillet welding.
- Input A
- Specifies a value for the A (Throat) size of the fillet welding.
- Groove
- Creates a groove welding.
