CORRIDOREDIT command
Adds or removes regions for a selected corridor.
Method
There are two methods to use CORRIDOREDIT command:
  • Add regions for a selected corridor.
  • Remove regions for a selected corridor.
Options within the command
Add Region
Allows you select a template for a selected corridor.
Enter region start station
The starting point along the 3D alignment line.
Enter region end station
The ending point along the 3D alignment line.
Note: The available intervals are displayed in the command window.
Remove Region
Select region to remove.
enter Index
Select index to be removed.
Note: Index is calculated from region start station to region end station.
