DELCONSTRAINT command
Removes dimensional and geometrical constraints from selected entities.
Method
Select one or more entities or type ALL to select all entities in the drawing to delete all their dimensional and geometric constraints.
Note: To remove individual constraints one at a time:
  • Dimensional constraints: select the dimensional constraint, and then press ERASE command.
  • Geometric constraints: click the tiny x on the constraint bar:
