DIMANGULAR command
Creates an angular dimension.
Icon:
Alias: DAN, DIMANG
Creates an angular dimension by selecting an entity or specifying the vertex and both
sides of the angle. The dimension is based on the current dimension style. Options allow
you to specify the angle and contents of the dimension text.
Methods to create an angular dimension
This command has 2 methods to begin creating an angular dimension:
- Select line, arc, or circle
- Press ENTER to specify angle
- Select line, arc or circle
- Begin creating an angular dimension by selecting a line, arc, or circle to dimension then:
- Other line for angular dimension
- Specify another line segment.
- Location of dimension arc
- Specify the location of the dimension arc.
- Other side of angle
- Specify a point to define one side of the angle. The point where you first selected the circle defines the other side of the angle.
- Begin creating an angular dimension by specifying the vertex of the angle then:
- First side of angle
- Specify a point to define the other side of the angle.
Options within the DIMANGULAR command
After you begin creating an angular dimension, the following options may be available:
- Angle
- Specify the angle of the dimension text. A value of 0 aligns the dimension text with the dimension line. Any other value rotates the dimension text relative to the x-axis of the current UCS.
- Text
- Enter text to override the default dimension text which includes the measured length of the dimension. You can use two angle brackets <> to display the measured length of the dimension in addition to other text.
