DIMCONTINUE command
Creates dimensions in a continuous line or arc.
Icon:
Alias: DCO, DIMCONT
Creates a continuous line or arc from an existing linear, angular, or ordinate dimension. The dimensions are based on the current dimension style.
Methods to create continuous dimensions
This command has 2 methods to begin creating continuous dimensions:
  • Origin of next extension line
  • Select starting dimension  
Begin creating continuous dimensions from the last linear, angular, or ordinate dimension by specifying a point for the next extension line.
For linear and angular dimensions, the first extension line of each continuous dimension coincides with the second extension line of the previous dimension.
Continue placing dimensions until you press Enter to end the command.
Additional options: [Select starting dimension/Undo]
  1. Last dimension
  2. Origin of next extension line
Begin creating a continuous dimension by selecting an existing linear, angular, or ordinate dimension then:
Specify a point for the next extension line.
For linear and angular dimensions, the first extension line coincides with the extension line nearest to where you selected the existing dimension.
  1. Starting dimension
Options within the DIMCONTINUE command 
After you begin creating a continuous dimension, the following options may be available:  
Undo
Undo the last dimension and continue drawing from the previous dimension.
