Creates a leader by specifying a sequence of points. The leader is based on the current dimension style. Options allow you to specify the format and annotation of the leader.
Methods to create a leader
There is one method to begin creating a leader:
Start of leader
Start of leader
Begin creating a leader by specifying a start point then:
Next point
Specify the next vertex of the leader.
To point
Specify the next vertex. You can continue adding unlimited vertices until you press Enter to access the annotation option.
Additional options: [Format/Undo/Annotation]
Annotation
Enter the first line of annotation text and press Enter or press Enter without entering text to access dimension text options.
Next line of annotation text
Enter the next line of annotation text. You can continue adding lines of text until you press Enter to end the command.
Start of leader
Next point (vertex)
To point
Annotation
Options within the DIMLEADER command
After you begin creating a leader, the following options may be available:
Format
Specify if the leader line includes an arrow and whether it has spline or straight segments:
Arrow: draw the arrowhead.
None: does not draw the arrowhead.
Spline: draw the leader line as a spline.
Straight: draw the leader line as straight segments.
Exit: exit the Format options.
Center
Undo
Undo the last leader line segment and continue drawing from the previous one.
Dimension text options [Block/Copy/None/Tolerance/MText]
Specify the type of annotation to use for the leader:
Block
Specify the name of a block in the drawing.
Alternate option: [? to list blocks in drawing/open file Dialog]
Copy
Select an mtext, text, block reference or tolerance entity in the drawing.
None
The leader line is created without annotations.
Tolerance
Specify tolerance using the Geometric Tolerance dialog box.
MText
Enter annotation text using the MText editor.
Enter * to list the names of all block definitions in the current drawing. You can also use * as a wildcard with other characters.
Open file Dialog
Select a .dwg file from the file dialog box to use as an annotation block.
