DMSTITCH command
Converts a set of region and surface entities that bound a watertight area to a 3d solid.
BricsCAD Shape; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM
Icon:
Method
Select the surfaces to stitch and convert them in a 3D solids or surfaces.
Note: If DMREPORTPANEL system variable is set ON, the result is reported in the Report panel instead of the Command line.
Options
MOde
Allows to set the validation mode either manual or automatic.
Auto
Creates only valid 3d solid or surface entities without free or non-manifold edges.
SOlid
Creates invalid 3d solid entities.
SUrface
Creates invalid surfaces.
Note: Creating an invalid 3d solid entities could be useful for understanding the reason of a failure. The command reports problems (free or non-manifold edges) and highlights them. You can either accept the invalid 3d solid by pressing Enter or refuse it by pressing Cancel.
Tolerances
Type a value or accept Auto.
Note: The selected validation mode is stored and re-used for future calls of the command.
