GOTOSTART command
Displays the Start Tab.
![BricsCAD Shape; BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-all.png)
Opens or activates the Start Tab.
Method
In the Start tab you can:
- Open a recent drawing.
Note: The number of available recent files is controlled by the
value of the RECENTFILES system variable.
- Create a new drawing.
Note: Click on Template to choose what template is used when
creating the new drawing.
- Open a drawing using the Open file dialog box.
- Access BricsCAD tutorials and sample drawings.
Note: Internet access is required.
- Access the Third-Party Application catalog on the Bricsys website.
