Creates a 2D spiral or a 3D helix from a combination of options including center,
radius, diameter, height, axis endpoints, turns, distance between turns, and twist.
Center of base
Base radius
Start turn 2
Start turn 3
Top radius
Height
Methods to create a helix
This command has 1 method to begin creating a helix:
Specify center point of base
Begin creating a helix by specifying the center of the base then:
