IFCVALIDATE command
Checks the quality of an existing IFC file.
![BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-bim.png)
Validates an existing IFC file before importing it.
Method
Opens the Import file dialog box to select the IFC file.
An IFC file validation report is displayed in the Command line, then you have to decide whether or not to import the IFC file.
Note: The report is also written to a log file next to the IFC file.
Options within the command
- Yes
- Imports the IFC file.
- No
- Does not import the IFC file.
