INSERTOBJ command
Opens the Insert object dialog box.
Alias: IO
Note: This is a Windows only command.
Opens the Insert object dialog box to insert an OLE object into the current drawing.
Alias: IO
INSERTOBJ command - BricsCAD Lite & Pro | Centro Assistenza Bricsys
