MLEADER command
Creates multileader entities using the current multileader style.
Icon:
Creates a multileader with three components: a leader line with an optional arrowhead, a landing line and the content, such as text or a block. Multileaders support more than one leader line per content.
  1. Mtext/block
  2. Landing
  3. Segment
  4. Arrowhead
Methods
There are three methods to begin creating a multileader:
  • leader arrowHead first
  • leader Landing first
  • Content first
Options with the command
Create a multileader by first specifying the location of the arrowhead.
Create a multileader by first specifying the location of the leader landing.
Content first
Create a multileader by first specifying the location of the content.
Leader type
Sets the leader type: straight, spline or none.
Straight
The leader is drawn from straight segments.
SPline
A spline is drawn using the pick points as the control points.
None
No leader is drawn.
leader lAnding
Specifies whether to draw a landing or not.
Content type
Specifies the content type of the multileader.
Block
Uses the block name you insert.
Mtext
Uses mtext; displays the MText editor.
None
Draws no content.
Maxpoints
Enter the maximum points.
First angle
Enter the first angle constraint.
Second angle
Enter the second angle constraint.
Grip editing
By clicking the green squares, you can edit the grip points of the multileader.
