MSPACE command
Switches from paper space to model space viewports.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Alias: MS
Switches from paper space to model space viewport in a layout tab. This command has a shortcut menu that opens by right-clicking on M:Layout on the Status Bar.
Note: This command operates only when a layout tab is in paper
space mode. To reverse the action of this command double-click outside the
viewport border, or use PSPACE command.
