QDIM command
Quickly creates a series of dimensions from selected entities.
Icon:
Method
The command is used for quickly generating a series of baseline or continued dimensions for each selected entity.
Select the geometry to dimension, then specify the dimension line position.
Options within the command
- Continuous
- Creates a succession of continuing dimensions where the lines are all positioned end-to-end on the same line.
- Staggered
- Creates a set of staggered dimensions where the linear dimension lines are spaced apart by a fixed distance.
- Baseline
- Creates a set of stacked dimensions starting from the same baseline.
- Ordinate
- Creates a set of ordinate dimensions with a single extension line with an X or Y value for each feature.
- Radius
- Creates radial dimensions and shows the radius value for the selected arcs and circles.
- Diameter
- Shows the diameter value of the selected circles or arcs.
- datumPoint
- Sets a new reference point for baseline and ordinate dimensions.
- Edit
- Adds/removes dimension points to/from the computed point set.
- seTtings
- Sets the entity snap priority.
