Creates a radial dimension for an arc, polyarc, or circle. The dimension is based on the current dimension style. Options allow you to specify the angle and contents of the dimension text.
Method
This command has 1 method to begin creating a radial dimension:
Select arc or circle to dimension
Options within the command
Allows you to begin creating a radial dimension by selecting an arc, polyline arc, or circle.
Location of dimension line
Specifies the location of the dimension line.
Angle
Specifies the angle of the dimension text. A value of 0 aligns the dimension text with the dimension line. Any other value rotates the dimension text relative to the x-axis of the current UCS.
Text
Allows you to enter text to override the default dimension text which includes the measured length of the radius. You can use two angle brackets <> to display the measured length of the radius in addition to other text.
