SMDELETE command
Removes features from sheet metal elements.
BricsCAD Mechanical
Icon:
Removes a bend or a junction by restoring a hard edge between two flanges. This command can also remove a flange with all the bends adjacent to it and it can remove miter by restoring geometry being cut by the feature.
The adjacent flanges are extended up to a junction configuration with the flange being deleted.
Method
There are two methods to replace features by hard edges:
  • Select feature faces.
  • Select thickness faces.
