TRACE command
Draws traces.
Icon:
Note: This command is rarely used as the PLINE command is more convenient.
Draws traces, like wide lines, with mitered vertices.
The trace is not drawn until the second pick point. The delay allows BricsCAD to determine the mitering needed at vertices, which this command does automatically.
Note: The FILLMODE system variable affects the look of traces.
