Creates a series of individual line entities by specifying the start and endpoint of
each segment. Options allow you to specify the angle, undo, and close the geometry.
Start
End
Close
Length
Arc
Methods to begin a line
This command has 3 methods to begin creating a line segment:
Start of line
Last point
Follow
You can continue adding unlimited segments until you press Enter to end the command.
Start of line
Begin creating a line by specifying the start point then:
