VIEWEDIT command
Changes the scale and hidden line visibility of a drawing view(s) if the view(s) was created with the VIEWBASE command.
Icon:
Note: This command operates only in Paper Space.
Method
Select the drawing view(s) for modifying by clicking inside one or more drafting viewports or press Enter to select all drawing views in the current layout.
The next prompt will vary depending on the selected view type. When different view types are selected, only the shared options are available.
Options within the command
Standard view options: see the VIEWBASE command
Section view options: see the VIEWSECTION command
Detail view options: see the VIEWDETAIL command
