VIEWEXPORT command
Exports drawing views.
Icon:
Exports drawing views generated by the VIEWBASE , VIEWSECTION or VIEWDETAIL commands to the model space of the current drawing, via the Clipboard to a new drawing or as a DWG/DXF file on disc.
Method
Click inside one or more viewports or select All views and choose the destination of the views (see options).
Options within the command
Clipboard
Exports the selected view(s) to the clipboard, which can then be pasted into any drawing.
File
Exports the selected views to a DWG or DXF file; displays the Save Exported Views dialog box.
Model space
Exports the view to the current drawing's model space.
Note: Specify if remove exported views:
  • Yes - the viewports of exported views are removed from the layout.
  • No - viewports of exported views are kept in the layout.
