Configure structure tree dialog box
The Configure structure tree dialog box allows you to define the tree structure of the Structural panel.
- File
- Group/Sort Tab
- Show/Skip
- Options
- Add
- Delete
- Move Up
- Move Down
- Toggle negation
File
Click the File menu in the dialog box and choose one of the available options on the
list:
- Open...: opens the Select Structure Tree Configuration File dialog box to select another *.cst configuration file.
- Save: saves the current configuration and keep the file dialog open.
- Save as: saves the current configuration under a different name and keep the file dialog open.
Group/Sort Tab
- Add () (5)
Adds a new rule.
- Select an existing rule, then click the Add icon () or right-click and choose Add Rule in the context menu.
- The new rule is added below the selected rule.
- Select the newly created Rule, then click the name or right-click and choose Rename in the context menu and type a new name for the rule.
- Select the Filter node of the rule, then click the Add icon () or right-click and choose Add filter property in the context menu.
- Select the Group node of the rule, then click the Add icon () or right-click and choose Add Grouping Property in the context menu.
- Select the Sort node of the rule, then click the Add icon () or right-click and choose Add sorting property in the context menu.
The Select Property dialog box displays.
Select a property, then double-click or click the OK button.
Optionally, type a search string in the Search field, then click the Up () or Down () arrow buttons to look up the properties containing the search string.
Repeat the previous step to add more filter / grouping / sorting properties.
- Delete () (6)
- Deletes a selected rule or property.
- Move Up () (7)
- Moves Up a selected rule or property.
- Move Down () (8)
- Moves Down a selected rule or property.
- Toggle negation (9)
- Toggle negation only for filter properties.
Show/Skip Tab
Select an option and then select the entity types to show or to exclude.
Options Tab
- Choose what happens in the model when entities are selected in the structure tree.
- Select what happens in the structure tree when an entity is selected/deselected in the model.
