CMDACTIVE system variable
Active command
Stores the type of the current command: ordinary command, transparent command, script, dialog box, DDE, lisp or ObjectARX command. The value is stored as a bitcode using the sum of the values of all selected options.
Read-only
Type:
Short
Saved in:
Not saved
Default value:
1
Possible options:
1: Ordinary command is active
2: Ordinary command and a transparent command are active
4: Script is active
8: Dialog box is active
16: DDE is active
32: lisp is active (only visible to an ObjectARX-defined command)
64: ObjectARX command is active
