Drawing 3D polylines
A 3D polyline is composed of linear segments in 3D space.
The 3DPOLY tool is available on:
- the Draw menu
- the Polylines toolbar
- the Draw Ribbon panel
General procedure
- Launch the 3DPOLY command.
You are prompted: Select start of polyline or [Follow] <Last point>:
- Specify a point.
You are prompted: Next point:
- Specify a point.
You are prompted: Next point or [Close/Undo]:
- Do one of the following:
- Choose the Close option to connect to the start point and create planar triangular 3D polyline.
- Specify a point.
You are prompted: Set next point or [Close/Undo]:
- Choose the Close option to connect to the start point.
- Specify a point.
- Keep specifying points or press Enter to stop.
Note:
- 3D polylines with assigned linetypes draw with an uninterrupted pattern. To make linetypes visible for 3D polylines, set LINETYPE3DPLINE system variable to 1.
- PLINEGEN system variable does not affect 3D polylines, and no other setting can change how the linetype pattern for a 3D polyline is drawn.
Editing a 3D polyline
- Select the 3D polyline.
The properties display in the Properties panel.
- Under Misc:
- Fit/Smooth: select None, Cubic or Quadratic.
The Cubic and Quadratic options create a spline representation of the 3D polyline.
- Closed: When set to No, removes the closing segment.
