TIN Definitions for editing
Overview
This article describes the TIN Definitions/operations available in the TINEDIT command or created from Civil 3D surfaces. It also describes the dialog box of each definition, where you can modify parameters.
These operations are also available in the Civil Explorer panel (see figure below).
Add point
The Add point definition creates a new TIN Surface or modifies an existing one based on specified locations and elevations of the TIN points.
To create the Add point definition:
- Select the Add Points option in the TINEDIT command.
- Right-click an existing TIN Surface in the Civil Explorer and select Pick points option from the Add group.
When you double-click the Add point definition in the Definitions tab of the Civil Explorer panel, the following dialog box opens.
- Name
- Point location
- Pick point
- Name
- Displays the TIN Surface definition name: Add point.
- Point location
- Displays the point coordinates.
- Pick point
- Allows you to pick a new location and set a new point elevation.
Add point groups
The Add point groups definition adds Civil points from a specified Point Groups to the existing TIN Surface or creates a new TIN Surface from specified Point Groups.
To create the Add point groups definition:
- Select the Add Point Groups option in the TINEDIT command.
- Right-click an existing TIN Surface in the Civil Explorer panel, select Add point groups from the Add group.
The following dialog box opens:
- Select box
- Point group
- Number of points
- Select box
- Allows you to select or deselect a point group to be included.
- Point group
- Lists all available point groups.
- Number of points
- Displays the number of points of the point group.
The Remove outer edges definition is automatically added to the TIN Surface after this operation.
When you double-click this definition in the Definitions tab of the Civil Explorer panel, the following dialog box opens.
- Name
- Displays the surface definition name: Add point groups.
- Point groups
- Displays a list of Point groups used to create TIN Surface.
Add breaklines
The Add breaklines definition adds selected linear CAD objects to the TIN Surface as breaklines.
To create the Add breaklines definition:
- Select the Add Breaklines option in the TINEDIT command.
- Create TIN Surface from linear CAD entities/objects and select an option to apply them as Breaklines.
- Right-click an existing TIN Surface in Civil Explorer panel and select Add breaklines from the Add group.
- Name
- Breaklines type
- Crossing elevation
- Mid-ordinate distance
- Supplementing factor
- Weeding factor
- Breaklines
- Pick button
- Name
- Displays the TIN Surface definition name: Add breaklines.
- Breaklines type
- Displays the selected breakline type. Select the appropriate breakline type from the drop-down list.
- Determines which elevation is taken for triangulation at the intersection of two breaklines, added in the same Add breakline definition.
- Adds supplementary TIN points along the arc according to the mid-ordinate distance which is used for arc approximation.
- Toggles the using of supplementing factor.
- Weeding factor
- Toggles the using of weeding factor.
- Breaklines
- Lists the breaklines included in the selected Add breaklines definition.
The table include sequence Number, Layers, Min. and Max elevation of the Breaklines.
Right-click an individual breakline in the table offers the option to Zoom to, Select, Remove, or Copy geometry to clipboard.
- Pick button
- Picks breakline in the drawing to select it in the table.
Add boundaries
The Add boundaries definition adds selected linear CAD objects to the TIN Surface as boundaries.
To create the Add boundaries definition:
- Select the Add boundaries option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Add boundaries from the Add group.
- Name
- Boundary type
- Trim triangle lines
- Boundaries
- Pick button
- Name
- Displays the TIN Surface definition name: Add boundaries.
- Boundary type
- Displays the selected boundary type. Select the appropriate boundary type from the drop-down list.
- Displays whether or not this parameter is used when adding a boundary to the TIN Surface.
- Boundaries
- Lists the boundaries added in a single definition and their layers. The context menu offers the possibility to Zoom to, Select or Remove a boundary.Note: Multiple boundaries of the same type can be added in one step.
- Pick button
- Picks boundary in the drawing to select it in the table.
Delete points
The Remove point definition removes points/vertices of triangles from the TIN Surface. You can delete individual points or select the option Multiple in the Command line to remove multiple points at once.
To create the Remove point definition:
- Select the Remove Points option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Remove points option from the Edit group.
- Name
- Point location
- Name
- Displays the TIN Surface definition name: Delete point.
- Point location
- Displays the coordinates of the deleted TIN point.Note: If the option Multiple is selected in the TINEDIT command (check the screenshot of the Command line above), then the dialog box displays coordinates of all deleted TIN points.
Swap edge
The Swap edge definition swaps the selected triangle edge.
To create the Swap edge definition:
- Select the Swap edge option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Swap edge option from the Edit group.
- Name
- Point location
- Name
- Displays the TIN Surface definition name: Swap edge.
- Point location
- Displays the XY coordinates of the swapped edge.
Move point
This definition modifies the location of a single or multiple TIN points in one step.
To create the Move point definition:
- Select the Point Location option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Point Location option from the Edit group.
- Name
- From position
- To position
- Name
- Displays the TIN Surface definition name: Move point.
- From position
- Displays the original coordinates of the TIN point before it was moved.
- To position
- Displays the new coordinates of the TIN point after it has been moved to a new location.
Modify point elevation
This definition modifies the elevation of a single or multiple TIN points in one step.
To create the Modify point elevation definition:
- Select the Point Elevation option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Point elevation option from the Edit group.
- Name
- Point location
- Use delta elevation
- Set elevation to
- Name
- Displays the TIN Surface definition name: Modify point elevation.
- Point location
- Displays point location of the point of which elevation was modified.
- Enables to specify the delta elevation (elevation difference).
- Set elevation to
- Sets the new elevation for the TIN point or delta elevation (elevation difference) if the Use delta elevation option is enabled.
Add line
The Add line definition adds new TIN Edge between two existing TIN points.
To create the Add line definition:
- Select the Add Line option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Add line from the Add group.
- Name
- Displays the TIN Surface definition name: Add line.
Delete edges
The Delete edges definition deletes TIN Edge inside the specified selection area.
To create the Delete edges definition:
- Select the Delete Line option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Delete line from the Edit group.
- Name
- Displays the TIN Surface definition name: Delete edges.
Remove outer edges
The Remove point definition removes triangles on the outer boundary of the TIN Surface, that have:
- greater edge length
- shorter edge length
- greater angle than specified
To create the Remove outer edges definition:
- Select the Remove Outer Edges option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Remove outer edges from the Edit group.
- Name
- Use Max. edge length
- Max. edge length
- Use Min. edge length
- Min. edge length
- Use Max. adjacent angle
- Max. adjacent angle (in degrees)
- Name
- Displays the surface definition name: Remove outer edges.
- Toggles the using of maximum edge length.
- Max. edge length
- Sets the value for maximum edge length.Note: Triangles with an edge exceeding the specified maximum edge length are deleted from the TIN Surface.
- Toggles the using of minimum edge length.
- Min. edge length
- Sets the value for minimum edge length.Note: Triangles with an edge exceeding the specified minimum edge length are deleted from the TIN Surface.
- Toggles the using of maximum adjacent angle.
- Sets the value for maximum adjacent angle.Note: Triangles with an inner angle exceeding a specified max. angle are deleted from the TIN Surface.
Minimize flat areas
The Minimize flat areas definition finds flat triangles and then swaps the adjacent edges of those triangles so that their slope is non-zero.
To create the Minimize flat areas definition:
- Select the Minimize flat areas option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Minimize flat areas from the Edit group.
- Name
- Displays the TIN Surface definition name: Minimize flat areas.
- Number of swapped edges
- Displays the number of swapped edges on the TIN Surface.
Remove elevation
This definition removes TIN points below/above the specified elevation and displays the number of points removed.
To create the Remove points above/below elevation definition:
- Select the Remove elevations option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Remove elevation from the Edit group.
- Name
- Remove points below elevation
- Elevation less than
- Remove points above elevation
- Elevation greater than
- Number of removed points
- Name
- Displays the surface definition name: Remove points above/below elevation.
- Toggles the option to remove points below a specified elevation.
- Sets the elevation below which points are removed.
- Toggles the option to remove points above a specified elevation.
- Sets the elevation above which points are removed.
- Displays the number of removed points.
Smoothing
This definition adds points to the TIN surface for smoothing it.
To create the Smoothing definition:
- Select the Smoothing option in the TINEDIT command.
- Right-click an existing TIN Surface in Civil Explorer panel and select Smoothing from the Edit group.
The Smoothing definition is automatically added to the TIN Surface after this operation.
- Smoothing method
- Adding points
- Smoothing area
- Grid X spacing
- Grid Y spacing
- Grid rotation
- Number of added points
- Smoothing method
- Displays the method for smoothing the TIN surface.
The Natural neighbor interpolation algorithm finds the closest subset of input samples to a query point and applies weights to them based on proportionate areas to interpolate a value.
- Adding points
- Displays the method for adding points to the TIN surface.
- Smoothing area
- Defines the area for smoothing. You can choose to smooth the Entire surface or a Selected area. To select the area, click the right side arrow to define the area in the Model space.
- Grid X spacing
- Sets the grid X spacing value. You can also define it by clicking the distance in the Model space.
- Grid Y spacing
- Sets the grid Y spacing value. You can also define it by clicking the distance in the Model space.
- Grid rotation
- Sets the rotation value. You can also define it by clicking the desired angle in the Model space.
- Displays the number of points to be added to the TIN surface.Note:
- If the number of added points exceeds one million, a warning message appears: "The number of added points is very high. It may take some time to smooth the surface."
- If the number of added points exceeds 30 million, another warning message appears: "The number of added points exceeds the allowed limit. Increase the X and Y spacing or reduce the smoothing area."
Create from Civil 3D surface
The Create from Civil 3D surface definition edits a TIN Surface created from a Civil 3D surface with the CIVIL3DIMPORT command.
- File path
- Source surface name
- File path
- Displays the path of the imported 3D Civil entities file.Note: You are enabled to change the file path.
- Displays the source surface name.
