Document tabs
For each currently open drawing, a document tab is located on top of the drawing area.
Document Tabs allow you to:
- Easily switch between all open drawings.
- Create a new drawing: click the + button on the right of the tabs.
- Close a drawing: click the X in the document tab.
Note:
- The SHOWDOCTABS system variable needs to be On to display the Document Tabs (On by default).
- When opening a DWG file via double-click from the operating system's file browser, the Start tab is loaded in Document Tabs if the STARTUP system variable is set to 2 or 3.
