3D command
Draws basic 3D mesh entities.
Draws basic 3D mesh entities, including boxes, cones, cylinders, dishes, domes, meshes, pyramids, spheres, tori, and wedges.
Options within the command
- Wedge
Draws 3D wedges (see AI_WEDGE command).
- Corner of the wedge (Start point)
 - Length of the wedge
 - Width of the wedge
 - Height of the wedge
- Pyramid
Draws 3D pyramids (see AI_PYRAMID command).
- First point of base (Start point)
 - Second point
 - Third point
 - Last point for base
 - Set apex of pyramid
- Box
Draws 3D boxes from polyface meshes (see AI_BOX command).
- Corner of box (Start point)
 - Length of side of box
 - Width of box
 - Height of box
(Finish by applying rotation angle of box)
- Cone
Draws 3D cones (see AI_CONE command).
- Center of base of cone (Start point)
 - Radius of base of cone or Diameter
 - Radius of top of cone or Diameter
 - Height of cone
(Finish by applying number of segments in cone)
- cyLinder
Draws 3D cylinders (see AI_CYLIDER command).
- Center of base of cylinder (Start point)
 - Radius of base of cylinder or Diameter
 - Height of cylinder
(Finish by applying number of segments in cylinder)
- Sphere
Draws 3D spheres (see AI_SPHERE command).
- Specify center of sphere (Start point)
 - Radius of sphere (Diameter)
 - Number of longitudinal segments
 - Number of latitudinal segments
- DIsh
Draws 3D dishes (bottom half of spheres) (see AI_DISH command).
Specify center of dish (Start point)
- Radius of dish (Diameter)
 - Number of segments around dish
 - Number of top-to-bottom segments
- DOme
Draws 3D domes (top half of spheres) (see AI_DOME command).
Specify center of dome (Start point)
- Radius of dome (Diameter)
 - Number of segments around dome
- Torus
Draws 3D tori (donuts) (see AI_TORUS command).
- Specify center of whole torus (Start point)
 - Radius of whole torus
 - Radius of body of torus (Diameter)
 - Segments around body of torus
 - Segments around whole torus
- Mesh
Draws 3D meshes (see 3DMESH command).
- First of four corners of polygon mesh (Start point)
 - Second corner
 - Third corner
 - Last corner for mesh
 - Number of segments – primary axis
 - Number of segments – secondary axis
