AI_PYRAMID command
Creates a 3D polyface mesh in the shape of a pyramid.
Icon:
Creates a 3D polyface mesh in the shape of a pyramid with three or four sides. The sides of the base may have unequal lengths. Options allow you to specify a pointed, ridged, or flat top.
- First point
 - Second point
 - Third point
 - Last point
 - Apex
Methods
There is one method to begin creating a pyramid
- First point for the base of pyramid
Options within the command
- First point for base of pyramid
 - Specifies the first point of the base of the pyramid.
- Second point
 - Specifies the second point of the base of the pyramid.
- Third point
 - Specifies the third point of the base of the pyramid.
- Tetrahedron
 - Choose this option to finish creating the base of the pyramid after specifying the third point to create a three-sided pyramid (tetrahedron).
- Set apex of tetrahedron
 - Specifies the top of the tetrahedron (1).
- Apex
- Top surface
 - Specifies the first point on top surface of tetrahedron, second point and last point of top surface.
- Set last point for base
 - Specifies the fourth point of the base of the pyramid.
- Set apex of pyramid
 - Specifies the location for the top of the pyramid.
- Ridge
 - Specifies the start and end points to create an edge at the top of the pyramid.
- Start of ridge
 - End of ridge
- Top surface
 - Specifies four points to create a face at the top of the pyramid.
- First point
 - Second point
 - Third point
 - Last point
